Base plates
Hello
I would like to see base plates in acrylic plastic or aluminium like Lego (See image below) have. This for stationary projects like a robot arm or other structure.
Images on lego base plates
It would be good if their where both round and squire plates in different sizes. And aslo the where holes for passing cabels true the plates and also 8mm holes for Flange Bearings
Could combine base plates together to build base structures as below
Example on base plate structure
Ofcurse the acrylic base plates above should have holes like the other mechanical Makeblock parts.
