Hi all,
at first my airblock was performing well. But after only one day it will not fly.
Firmware is up to date, calibration done when LED is green-green-red says it is ok, but when you start the drone and hit UP, motors will howl, drone starts to gain maximum 50-80 cm height for 1-2 seconds and then all motors are going instantly off and the drone crashes.
Hovercraft mode works as expected.
I have tried many approaches / hints from the forum to no avail.
At last I removed all motors and tested the outputs from the control “block” with voltmeter when moving the controls. It showed me up to 7,5 V.
So I used stabilized power supply and tested all motors. At 7.5 V they will draw about 0.52 A and howl properly creating some airflow.
All of them but one - the “RED DOT” is drawing more, but rotates slowly (just like “standard” on). Compared to this the other motors will be in “fly mode” at this current/voltage - howling and producing steady airflow.
Is this normal? What can I do?
Thank you very much in advance for you help!
Emil
